Discuss Flexible gas sleeves in the Gas Engineers Forum area at PlumbersForums.net
Just wondering what is classed as a flexible gas sleeve for gas pipes on timber framed buildings?
Do you mean flexible gas pipe for transition fitting between the solid and timber building ?
Check the link out and no only need to transition eg from solid to timber building
Reply to Flexible gas sleeves in the Gas Engineers Forum area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
