Currently reading:
flexi pipes vs solid pipes
Discuss flexi pipes vs solid pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
articoceanic
Hello
My bathroom has had solid copper pipes to all the taps, but my plumber is replacing it with flexi, after i asked for them to replace the stuff.
Am i being ripped off with an inferior service? flexi will leak sooner or later will it not.
regards
if you want copper pipe it will cost a bit more time, have you ever known a garden hose never to split in time!!!
Flexi's hoses tend to be used when price is a determining factor ie plumber not being paid a lot or the plumber is not a plumber and is in fact a handyman/ chancer
Another factor in this is if the supplied brassware came with braided hoses then that's what's getting fitted! If it's decent gear and fitted right then at the very least it will be covered by the warranty.
tbh flex's on taps and hard pipe on bogs, thats what i do unless commercial (and you have peoples pulling the flex part) its easier when you come to change taps later on
I would go with copper pipe every time. It's not that hard to a plumber to bend accurate pipes.
I use them to connect onto taps , they are no difference in price infact there more expensive than a tap adaptor TBH,
Me personnally i dont feel your being ripped off articoceanic and just because hes used flexis i wouldnt deem the guy a diyer either ,, not if his work is spot on but only u know that mate,
I really dont understand what the big deal is about flexis , its only 300mm of a braided hose,
I remember when plastic came out, all engineers said thats for diyers and now most use it lol
Flexis are great love them
When you look at any top end taps that are they supplied with!!!
Think that says it all
Flexi tails on taps are pretty much the norm now. It only really needs to be in copper if the flow rate is really poor and i am doing everything i can to not restrict it further
I'm still avoiding flexi's where I can. I tend to fit taps which come with copper tails.
I've got a few long speedfit flexi's on the van which I use for temporary connections though.
This ^, if we like it or not most monoblock taps come with them these days and they are becoming more popular. For taps/cistern connections i really don't see the problem :)
Do many tend to use flexis when piping up baths, find it alot easier.
Yeh I certainly do, there quicker , easier and in most taps supply flexi tails anyway ,
The problem with flexis is how its installed. As long as its not kinked, twisted or stretched it will be fine.
Personally I use both, if the taps come with flexi then that's what gets used, if not then its ridged
yea use both depends on the situation, i would say doing it solid would last longer and with that its probably good practice to use flexys where they could be accessed and checked over.
{thats just an opinion though} ...
old plumber becomes wise plumber, especially when thinking of retiring and flexis start to seem to be the answer if installed correctly. :)
Flexis are good. I don't like the ones with inbuilt iso valves tho. As long as it's not all twisted up and installed by correctly they're great.
I have started using the the speed fit 1/2" or 3/4" femail to 15 or 22mm" pushfit with copper pipe in...... you get the ease of installation, no flow restriction and can get the brass nut version that looks better
I do go to more leaks on ridged with fibre washer then I do with flexis
Flexi's can spring a leak when installed properly and not twisted or kinked but it's very, very rare. And most leaks in tap connections occur at the connecting nut' washer (in which case rubber washer in flexi miles more reliable than fibre washer in rigid)
I'd say liklihood of leaking in order of least to most is:
Rigid but with something like a speedfit tap connector at the end
Proper installed flexi
Proper installed rigid with fibre washer in standard tap connector
I replaced a couple of kinked flexi's to bath taps with this arrangement. I reckon it's pretty much bullet proof.
Went to a job this moaning where the flexi had split at the nut, gushing water everywhere,
It wasn't kinked twisted or anything,
Either over tightened or cheap and old,
I still replaced it with a new flexi though
they have been using flexis in spain at least ten years before uk allowed them to be used ,they dont have much problems with them or legionaires disease .
Hello legionnaires disease
If i have to use flexable hoses then they are WRAS approved ones. These have been tested to prove the epdm rubber doesnt promote bacterial growth within the hose. But that said I'd still avoid using in a health care setting.
Reply to flexi pipes vs solid pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
