Discuss Flex tap connector washers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
All flexible tap connectors I have seen with 1/2 inch ends have rubber washers yet the Toolstation and Screwfix catalogues lists flex tap connector washers as fibre washers, does anybody know why this is?
I have used the fibre washers a couple of times. Some clown had a flexi coming out of some tiled in boxing and then graunched up the connection to wc inlet and cut the rubber washer - it was use a fibre washer replacement (2 minutes) or get into boxing and repair all (at least half a day...)
Cos most of the time theses people have no idea! Often when they add 2 & 2 it makes 5...
Reply to Flex tap connector washers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
