Discuss flange or no flange? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
SPencer DIY
I am fitting a new shower valve, it has 1/2 inch compression female in/outlets.
I am using a 1/2 in ch to 15mm elbow to get me into my copper pipe network.
Should I use a 1/2 - 15mm adaptor with a flange or without a flange?
What is the flange for anyway?
With a flange and tapered thread if you can
Reply to flange or no flange? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
