Discuss Fix plumbing problem in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
How to fix this?
I am in a pickle here. Have to converge water two pipes into one. He fixed something honey trap or something idk.
Reply to Fix plumbing problem in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I recently had a plumber come over to look at a badly leaking shower head. As best I can recall, he described the problem as a crack in the bridge...
Hello all I have had an extension built which will have 3 radiators to the big main room, a utility sink and a shower room (ground works, waste...
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have...
Hello I have a condensate pipe that appears to be leaking at the joint. How do I fix the leak? Would something like plumbers putty around the...
hi i have a drip leak from the bottom of this pipe see attached how do i fix it is there a video that would help me cheers
