Discuss find out depth between two manhole in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
John Matthew
i have two mh cover nd invert lvl nd i need to find out some depth between two manhole
Very long clear hose fed between both and filled with water will give you the level of one, measure the difference or a surveyor's optical level.
dear gmartine
my question is need to find out some depth between two manhole
dear steveb
do u know that slope of pipe ? i mean which i attached above
Depth from manhole cover to invert are:- 4980 and 6280 . Difference on level of manhole covers 3000 minus 3070
Difference in level of inverts 6280 minus 4980 equals 1300. Less difference in cover level 070 equals 1230
Size of pipe 900mm, material GRP. Distance between manholes 156520
Slope off pipe :- 156520/1230 equals 1: 127 approx.
Slope of 1/127 is normal for pipe of this size. Dimensions in mm for clarity.
dear joni os
tnx for the info (Y)
is there any formula bro ?
Formula for slope is the distance between two points, measured horizontally, divided by difference in level, measured vertically. Always using same units of measurement. I suspect you are seeking a formula for something different. What is the nature of your intended works.
right now i'm taking qty of pipe length bro actually as per BOQ (bill of quantities) they need qty depth wise
for Exple
1. dia 1000 how many mtrs depth 0-3 nd 3-6 nd 6-9
2. dia 1200 how many mtrs depth 0-3 nd 3-6 nd 6-9
like this bro
For estimating purpose- 4.980 is so close to 5 metres I would ignore the difference. This would give you :-
Length of pipe between 5 and 6 metres deep, equals 127 metre. Pro rata if B of Q has different splits.
Length of pipe between 6 and 6.3 metres deep (156.52 minus 127) equals 30 metres.
More accurate calculation :-
Difference on depth between both points 1.300 over distance of 156.52 metres. Slope of pipe relative to slope of ground 120:1 if B of Q splits depth at 300mm each 300mm will contain 36 metres of pipe.
Reply to find out depth between two manhole in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
