Discuss LCS to new water mains in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new thread so what's the best way of connecting the two?
Cheers,
Peter
Philmac utc (universal transition coupling) is the best bet and best way
Reply to LCS to new water mains in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
A
Hi, I am replacing a kitchen tap and have run into some trouble when connecting the flexi hot and cold pipes to the hot and cold mains pipes. The...
Adam tl
A
Hi I have a question, I want my flat to be separately connected to the mains water supply for water coming into my kitchen and bathroom instead of...
Hi everyone, How do you know if there is a cross over with the pluming system in flat? All pipe work under sink, bathroom etc in the flat itself...
Hi everyone, Just wanted some confirmation regarding a PRV fitted to the mains supply in my building. All 6 flats in the building are now...
Hi, We have a Kinetico 2020c HE Water Softener, fitted in 2008 in our loft to the cold water tank in a vented system with a conventional boiler...
1K
