Discuss Filie regs ........ please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
What does this mean?Looks ok from my house.
It’s foam is H the right thing 500mm?It means I’m joking around Ron. Is that corrosion on the flue collars?
Yes if it’s openable it has to be 300mm away doesn’t it?Also is that a sky light on the flat roof?
Could t find what I was looking for. I found something else of VaillantWhat does it say in the instructions
300mm? Don’t believe thatPg 55 in the manual from a vertical structure on the roof
Thank you very muchH - 500mm
The 300mm is for vertical structure at300 mm the wall is a vertical structure
Don’t know what instructions they are but there not the I q ones
https://www.vaillant.co.uk/download...nce-instructions0020193968-03-pdf-1413944.pdf
You have the wrong instructions shaun. That boiler is too new. The one fitted is much older look at the flue inside.300 mm the wall is a vertical structure
roof top but not for flat roof with a brick wall. It’s 500mm
Disagre due to having a vertical wall next to the flue. Pitched roof will have a lot more air and wind.Roof is a roof flat or pitched doesn’t matter
He doesn’t have an 835 the 835 is the boiler he is putting in.
Sorry perhaps it’s me again.He doesn’t have an 835 the 835 is the boiler he is putting in.
Yes mate. This post looks like you are asking if this is ok.Sorry perhaps it’s me again.
I would like to Install a new 835 green IQ and therefore I am after the right distance to the skylight and vertical brick wall
Sorry mate. OP was misleading.He’s replacing the boiler
“Thenext boiler will be a Vaillant 835 green iq”
But I disagre with 300mm as it’s not at the roof like in the manual letter P.Sorry mate. OP was misleading.
If you both say that I will just call once more Vaillant to find out. Is not that I wouldn’t trust your experience it’s just to make sure I am doing the right thing.From a vertical structure on a roof Ron. It is there in black and white. You don’t have to agree but it is right.
Don’t get me wrong I am not doubting your experience just want to make sure I’m doing the right thingPg 55 in the manual from a vertical structure on the roof
Sounds like you are mate. Why post on here if you are going to ring Vaillant anyway. Better off just calling Vaillant.Don’t get me wrong I am not doubting your experience just want to make sure I’m doing the right thing
I want to make sure when i Install the boiler that’s to spec. As I disagree with one figure I want to make sure so don’t be so fragile and try to understand me.Sounds like you are mate. Why post on here if you are going to ring Vaillant anyway. Better off just calling Vaillant.
Reply to Filie regs ........ please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
