Discuss Ferroli Optimax Heat Exchanger in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bewsh
Have any of you guys ever changed the main heat exchanger on one of these god awful boilers???
Had a right ******* doing it! The sump gasket is a tiny bit too small so need to stretch it over, but everytime you get over all 4 corners and let go, at least one corner would pop off! You need to place the heat exchanger on top of the gasket quickly before it pops off!
A little tip if you are unlucky enough to do one, get some small crocodile clips and clip the seal down on the corners, but be careful they don't tear the rubber gasket.
youre crazy :smile5:, how much did that cost?
if a Ferroli needs a new heat exchanger, then you need a new boiler
Nope, if they are leaking it is time for a new boiler.....
or easier way to sum it up, 'if you have a ferroli you probably gonna need a new boiler soon'
Lol.
Unfortunately not that easy, customer pays monthly contract. Think the heat exchanger was almost £400.
Reply to Ferroli Optimax Heat Exchanger in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
Morning to any Australians lurking around! Register its free, then message me, I'll sort your account out for you. We will need a moderator from...
