Discuss Fernox Leak sealer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
novicegas
Hi all, Just out of interest how does the leak sealer work, and why and how does it not seal the air pressure relief?
Ummmmmm that's a really good question dam it got me thinking now :(
It reacts with atmospheric pressure. When it's circulating and detects a small leak with air present, then it reacts with the air to form a membrane to seal the leak. It only seals small leaks. Larger leaks need you guys.
Reply to Fernox Leak sealer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
1K
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so...
Hi all, just moved a radiator from one wall to another, straight forward job, heating is working, problem is that on turning on a hot water tap...
Hello I have a condensate pipe that appears to be leaking at the joint. How do I fix the leak? Would something like plumbers putty around the...
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have...
