Discuss faulty 3port in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
mkflow
hi,
can a faulty 3 port divertor valve not switching over to c/h cause boiler to overheat and display f4 on glowworm??
Need a bit more info, what model glowworm? does the pump continue to run once HW is satisfied and it should be switching over the CH?
Can you manually open the valve and lock it in the open position to see if that stops the error code?
no you cant manually move valve as motor ---- . when h/w satified boiler goes lockout
Reply to faulty 3port in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a 4 zone / 7 loop UFH system. 2 zones (4 loops) always get hot when the system is on when the zone thermostats and actuators are...
1K
Following on from my question about monitoring F & R temperatures, I needed a measuring device because the overheat stat. frequently trips and...
1K
C
Apologies - I am not a plumber - not sure if it is ok to post here but... It's freezing and my boiler is not working so, I wonder if anyone can...
Hello. Today I have installed a new radiator upstairs. A little bit bigger so I had to make new pipe work. Before that I flushed as much water...
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water...
