Discuss Farting boiler, any ideas???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello
Just to ask, I have just had a boiler fitted recently and it seems to be 'farting/rumpling!! When the temp in increased or the boiler starts up it seems to go. I noticed not all the water drip our of the boiler chimney. Could it be running back into the boiler? I did read about the combustion mixture could be out? Its in warranty
can anyone help or advise?
Seriously though, any concerns or questions should be aimed back at the installer. Especially if it's a recent install.
Reply to Farting boiler, any ideas???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
