- Messages
- 3,311
Hi all,
I was wondering what you would consider a fair price to hang a new system boiler in a loft and connect on to all pipework plus test and terminate the new gas pipework at either end. We would be installing all pipework and taking responsibility for all of it except the gas pipework. We would run the gas pipework as per how the gas fitter wants it and he would then test it and do the final connections.
A roofer will be present on site on the day of installation to connect up the flue through the flashing plate on the roof.
New boilier is going in the loft. Lighting, ladder, flooring and a decent sized loft hatch will be provided prior to him arriving.
All pipework will be in correct positions in the loft so that all is required is the gas fitter brings the pipes up directly into the boiler. A fused spur will be provided to power the boiler and all system controls and radiators will be in place (and pipework pressure tested) prior to him arriving.
He will also need to disconnect the existing boiler from the gas supply, it is already fully drained down. It is a floor standing boiler with easy access to the gas pipework.
Basically I am doing all I can to minimise the amount of work he has to do but I want both of us to feel we are getting a good deal out of it.
We will also be supplying the boiler and flue etc (Viessmann Vitodens 100-W 26KW System Boiler).
