Discuss External warm water dog shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am currently looking into putting a cold/hot water supply to the outside of a property to then fit a dog shower and some sort of tray.
My question is: Is it feasible to put a hot water supply from the interior, through the wall to an outside tap?
What kind of fittings would you recommend to achieve this if it is possible?
Thanks in advance
Yes this is possible piped from inside you property see attached . cheers kop
my friend has fitted a few he uses a mixing valve the the outside tap
Sorry to say you can't unless you follow the cat 5 backflow rules eg break tank etc (no mains supply)
Reply to External warm water dog shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
