Discuss External 15mm pipe insulation in the USA area at PlumbersForums.net
Plumb Tidy
Hi lads and lasses sorry if this has been covered before but i couldn't fins anything on it. Im installing an outdoor tap and for the first time the pipework has to be external. Im fitting it to water regs standard with all the rubbings internal pipe sleeved out the wall then runs down 3 meters to the tap.
Im after advise on what insulation to use it needs to be water proof and u/v resistant i was looking at HT arm flex however is says for 15mm pipe it won't stand up to -6 for 12 hours without freezing and local water supply regs recommend this as a minimum. I phoned Welsh water they wasn't interested they said use what ever the customer can afford as we do not have a spec on freezing times.
Anyone have any advice on this or what you use. I know its unlikely to be -6 in this country for 12 hours and i know how things are done in the real world I'm just trying to cover myself and get some knowledge on the matter.
Cheers!
arma flex toughcoat with trace heating but in reality tell them to drain down the tap in winter dont leave it on
also dont cut for pipes clip the insulation eg 52mm clips
eg something like this
barrier least if it does freeze its got some give
Reply to External 15mm pipe insulation in the USA area at PlumbersForums.net
