Discuss estimated the water volume in the Plumbing Jobs | The Job-board area at PlumbersForums.net
TFGplumbing
How can I estimated the water volume of underfloor heating? so as to size the correct expansion vessel?
I don't know the exact length of pipework that's been installed as i didnt install it
Depends on pipe centres , lengths etc ,,,, u can roughly say Water Volume @ 200mm centres = 0.85 litres per sm,, but your pipe centres may differ ,
Allow for 150mm centres and you should be OK
Better to be slightly over sized on the vessel than under
It's not a real science, I'd say go a little bigger if your concerned...
Reply to estimated the water volume in the Plumbing Jobs | The Job-board area at PlumbersForums.net
How it best to install pipework to best avoid airlocks with gravity hot water. Install level or slightly down hill in direction of flow? Thanks
Sonya K
