Discuss Essex flange leaking from hwc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jitenbulsara
Morning
A question for anyone who has attempted to repair a leaking Essex flange side exit.
Is it worth trying to repair a leaking flange by drain down cylinder below flange breaking free the external nut if possible and use hemp n boss white to re-seal as long as the nut tightens up?..
Any advice as I'm not in the position to take out a lot of time to change the cylinder as they have built couboards n it's right in the corner and will have to cut loads of pipe work just to get cylinder out n the new one has the extra insulation too.
Any advice would be great
When you are going to the bother of draining etc why not just replace? Although I have bodged them as you mention as a temp fix.
However long it takes then price for that
If you don't want to do it then don't
What's the problem?
Take a new one with you. The seal is on the inside ( as you know), make sure the surface inside the tank is clean and smooth and the new flange will fit lovely.
If it is leaking the problem will normally be that washer on the inside.
I'd do it.
Not a bad little job with a brew n biscuits, radio Christmas songs, Nice n warm inside.
Go on, Enjoy yourself.
Don't be tempted to use paste, silicone! Lsx etc. This will make the rubber washer spread. It then won't seal against the thread. These joints are meant to be used with just the washers.
For the cost, I would just remove tho old one and fit new.
Reply to Essex flange leaking from hwc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I have a problem with a leaking Essex flange mentioned previously.I have tried various fixes but it always starts weeping again. I may be...
2K
Hi This is my first post as a homeowner/DIYer Hopefully the title explains my question ; I want to replace the washer on an Essex flange as the...
2K
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
My step-daughter bought a 50's end-terraced house at the start of the year, and found there was a leak from Mira bar shower that was coming...
2K
Hi I fitted a bath/shower 12 years ago and a few months ago it developed a leak. It was basically at a coupler on 40mm solvent where my new...
2K
