Discuss EN417 to 1" UNEF Propane Convertor? in the Plumbing Tools area at PlumbersForums.net
I bought a torch a few years ago that uses EN417 butane/propane cylinders.
As someone who only uses a torch now and again, the torch has been fine on smaller copper pipe but struggles on 22mm, especially in the cold.
I have seen an adaptor by Monument (437a) which I think should allow me to run Propane or even Mapp cylinders which would give me the extra heat...
Given I like the actual torch and the adaptor is only about £15 which is considerably cheaper than buy a new torch, is there any reason not to go down this route?
Thanks in advance,
Peter
Reply to EN417 to 1" UNEF Propane Convertor? in the Plumbing Tools area at PlumbersForums.net
