Discuss emergency call out rate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Rybo_1
Evening all,
Came off the phone with the boss earlier after him asking me what £/ph I would be after if we were to take up a contract with a letting agents for emergency call outs. We, as a company already do general maintenance for them. I'm based in SE England and all work within an hours travel
I was after some.advice as in to what the average rate is for this sort of work. I was thinking of going back to him with two different time brackets. Say 5pm till 11pm and then 11pm till 7am.
What do you all think?
Cheers
When I did it it was time and a half between 1700 and 1800 then double time from 1800 onwards, didn't work past midnight ever.
have a look at pimlicos fees, then go back to the boss, but not many lettings agencys would pay what anyone wants.
Evening all,
Cheers
As a Self employed plumber, my emergency call out is quite high, and I decide a price depending on what time and day it is,
But remember,
If you go to an emergency call out, your still in work the next day a X o'clock just with less sleep
You might end up missing out on a nice meal/date with the other half, (there never happy when you cancel plans)
Once your up in the middle of the night, have drove somewhere and sorted the fault, you might not get back to sleep and be in work the next day or out with family
This is why my emergency call out is high as I don't live to work, I work so that I can live
Ask if he is going to pay you a stand by rate, or if he's just expecting you to be called out, at any time, it needs to be done on a rota, So much for stand by, (inconvenience money) with a minimum pay of 2hrs
Tell him no amount of money's enough, call out is $hit.
2 & 1/2 time min 2 hours if called out then per hour
he should be charging client at least £150 per hour so go figure that out while he's in bed.lol
Reply to emergency call out rate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the existing boiler needed upgrading. The Mechanical Engineers advising the architect insisted that we had a conventional cast iron combustion chamber boiler...
1K
Hi everyone, I'm a (somewhat, I hope...) competent DIYer and just want to get some advice if my suspicion on a problem we're having is correct. We had a Megaflo and boiler professionally installed as part of a renovation a couple of years ago. I will add all of the pipework was done by this...
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be making things worse. I really need another expert's opinion, to put my mind at rest, or help me make the decision to stop using his services. I...
3K
I have a contract with HomeServe to supply "emergency" plumbing service should I ever have a problem. Recently I was clearing out the gutters using a plastic yogurt-pot-type-thing to scoop out the crud. Unfortunately, this pot fell down the soak-away pipe that the gutters drain in to. I called...
2K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm. This question is for my own house setup. We are really fortunate to have a large house, about 5,000sqft in total over 3 floors. It was built around...
1K
