Discuss Elson Sapphire double feed indirect hot water tank in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a fairly modern multifuel stove with a back boiler connected to a Elson Sapphire double feed indirect hot water tank and I need to drain down the system to move a radiator.
Would anyone be able to offer any advice as to the correct drain down and refill procedure for this tank as they only have a single cold feed cistern for the Domestic Hot Water side, the primary indirect Central Heating feed and expansion from the back boiler seems to be internal to the tank and from what I can gather is a type of primatic or spartan vessel.
Any advice would be much appreciated!
Reply to Elson Sapphire double feed indirect hot water tank in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
