H
handsomejackuk
Have had a heated towel rail fitted for a few weeks, and managed to pick up an element today cheaply... the rating on the towel rail is 150w, and the element is 400w.... i only want to use the heater on electric, as to plumb it in is real awaward position....
1st question is what liquid do i need to fill the radiator with...?
water..... oil...... or water with antifreeze / rust inhibitor...?
how much water does it need i understand that water expands when heated so is it best to fill it just below... turn it on for a while then adjust level when the rad is hot...?
how can i alter the tempertaure ?
is the tempaertaur set on the element.., or do i need a seperate theromstat...
picked up the element for £5.00 so if its not suitable for this radiator i can use it on something else anyway..
any advice. ?
any advice. ?
