Discuss Electric shower instal tips in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Plum Bob 66
Hi
I have been asked by a customer to install an electric shower. From the plumbing point of view can you give me any tips on the best way to go about the install and the order the work should be undertaken. I have an electrician who is part p to do the electricals so it is purely from a plumbing point of view. This is my first since undertaking my training and want to get it spot on.
Thank you in advance.
Plum Bob :)
cold feed from mains to shower - dont use a feed from tank if there is one. bobs your uncle - easy job.
use chrome pipe and fittings if the pipework is surface mounted
Also remember to fit an isolation valve. After you've done 3-4 of these there's nothing to it and no need to read the instructions any more (well, not till after you've finished just to make sure you did do everything correctly!)
I use my own screws/rawplugs as I trust them more than the manufacturers' stuff.
i always use my own fixings for everything its just personal preferance
check the basics before install,is the cold main to slow or to fast
Pressure/Flow check and correct size breaker/cable in place for new install.
I think the minimum supply by water company is meant to be 1 bar and 9 litres flow per min.
well mains should always be sufficient, and 'electrics not my job love', shower will be fitted in place and up to spark to connect. even though i know about cable sizes and what is required for the different kw showers i keep out of all that. If she wants i'll get my spark mate to sort it out and price accordingly (more ÂŁÂŁÂŁ's for me pricing for him)
MUST legally be accompanied by an Electrical Small Works Certificate completed by a registered Part P technician.
Reply to Electric shower instal tips in the Plumbing Jobs | The Job-board area at PlumbersForums.net
First - an apology for monopolising the forum with all my plumbing questions! I'm hoping this will be my last and I'll move onto something else...
2K
Hello all I have a pressure problem in my shower. I am on the 3rd floor. I have put a 25m 15mm plastic pipe through the roof space to nearly...
1K
Hello All and thanks Lou i did write a reply but it would not let me send it? i am not sure what I am meant to write and I do not want to come...
Hi guys, I'll try to describe my issue as best I can but I've attached a video and linked to some images below that might do a better job of...
2K
Ah, the joys of older home ownership (1974). We thought our major plumbing issues were dealt with when we got rid of our orangeburg sewer line and...
2K
