Discuss Ease of changing a lever flush to a button flush in the DIY Plumbing Forum area at PlumbersForums.net
Is it possible to change a lever flush handle for a push button one using same cistern? If so any pitfalls I should look out for.
You can use a stnd push button fluidmaster and use the riser adapter for the button doesn't look the best but works
As snowhead says, yes, you can get specific conversion kits, but personally I wouldn't recommend it as when flush valves fail they usually leak continuously into the toilet pan, giving little indication to anyone who isn't looking for it that they're wasting gallons of water a day.
Perhaps it's worth doing if it is for your own use, but I have had to deal with three of these in holiday lets that had probably wasted thousands of litres before I spotted them: two of which while on other jobs and the third when looking for unidentified water losses while the property was vacant during lockdown.
Lever opreated siphons fail obviously and without any water loss.
Thanks for all the replies guys. Only reason for doing it in the first place was to change the seat for a soft close one. When i fitted the new seat it would not stay upright as the lever stopped it going back far enough. I might just do a revamp and change the cistern as well as it has probably been there since time began.
Reply to Ease of changing a lever flush to a button flush in the DIY Plumbing Forum area at PlumbersForums.net
Hello all, I have just joined, after being pushed into some DIY plumbing. Here is my first plumbing DIY effort. I had a cistern lever that...
Hi there, can anybody help? I am trying to buy a replacement toilet flush push button as my current one is broken? However I cannot find the same...
Hello, I have a question on flush pressure. When I press the bigger button, there's hardly a flush. I understand that's normal but it's a very...
My toilet flushes ok when the long flush button is pressed - but water continues to flow into the toilet bowl. No problems with the short flush. I...
Hi all, I am trying to find an alternative flush valve to fit the cradle of a ideal standard push btn flush. It is all tiled in and changing to a...
