Discuss Dungs mbdle gas valve setup in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello.
I am looking for a detailed commissioning procedure for the dungs mb_dle range of gas valves.
I have been given conflicting information.
Thank you
what have you been told?
Starting point of the governer is three turns back from + or 10 turns open from -.
Also have been told to rate the burner with the aluminium adjuster then add an extra millibar but take this millibar back off with the governer.
Another version was to reduce governor until pressure starts to drop then leave it there.....
Am confused what' right??
Thank you
Do you need it for tomorrow as I've got a pdf or can you wait til tomorrow night when I'm back at the comp to upload it ?
as promised hope these are what your looking for (think the powermatic ones should do you)
  • Dungs Set Up And Spec (MB,DM).pdf
  • Powermatic CPx, CP, CAG Dungs Set Up.pdf
Reply to Dungs mbdle gas valve setup in the Plumbing Jobs | The Job-board area at PlumbersForums.net
