Discuss Dropping flow rates over time. in the USA Plumbers Advice area at PlumbersForums.net
Hi folks.
I'm looking for advise for troubleshooting dropping flow rate that I could look into myself until we are up and running and I can get a professional in.
Over the last 6-8 weeks I've noticed that our water supply is dropping in flow rate and today I measured a tap running at 3.5 litres a minute whilst no other user was online.
We have an external tap that flows at +20 litres a minute and pressure of +4bar so I am confident it's not mains supply. (I'm rural so not got an immediate neighbour.
I've not been able to measure the pressure in the house but can only hold the pressure back with my thumb for about 10 seconds.
Some info
Single story cottage originally 1890 build but many changes over the years
External Worcester Oil fired boiler. for CH and DHW
I'm suspecting that the boiler is tripping on low flow when running shower, it's gone cold on 2-3 occasions.
Initially the tap runs fast but drops after a couple of seconds.
I am thinking I have a restriction somewhere that will need looked at. Does this sound right to the professionals?
Any insight appreciated
Cheers
Ok. So the outside tap is fine. Are both hot and cold suffering reduced flow in side the house? Do you have a pressure reducing valve on the cold main after outside tap?
Yes both taps. I have not found any pressure reducing valves and I sweated my erse of in the attic today following lines. Tomorrow I am going to look at what the flow is like at the filling loop point at the boiler.
Would agree with @SJB060685. If your outside tap is OK then it's obviously something after this, and tbh as he has said sounds like a faulty pressure reducing valve or strainer.
Is your outside tap on the same main as the house - as in the tap supply comes from within the property after the stoptap? Or is it feed from the cold supply underground before it enters the house.
The tap is after the Stop tap and before the house so yes on the same supply.
I'm going to get in touch with the guy who had the house before me to see if he recalls where any reducers or strainers might be. I've discovered a few times that he had a rather unique approach to DIY. I've also got a plumber who replaced a lot of the plastic lines that that the former owner fitted but did not bother to include inserts at joints who might recall something.
Yesterday I shut the house side stopcock and emptied the system and opened it up again. I repeated this twice and I have managed to increase the flow to 7litres/minute which will suffice just now.
Cheers for all the replies
Too maximise your flow rates for now make sure all stopcocks are fully open. After that pursue as we have mentioned
Hi folks
An update
With the help of a decent plumber(but useless at turning up when they promised for a week :) ) we got the problem sorted.
We found a stopcock from back in 19oatcake hidden behind a 3rd layer of plasterboard, the washer in this valve had perished and slipped to partially block the line..
During this journey I've also discovered that at some point in the past one wall of our house has been underpinned and embedded in that concrete is the T that splits the domestic supply from the outside tap. FFS
There is also still the BT master socket behind plasterboard somewhere else but that's for another day.
I got 6.5 bar and happy.
Thanks to all who replied.
I've got another question but that will have a new thread
Reply to Dropping flow rates over time. in the USA Plumbers Advice area at PlumbersForums.net
