Discuss Dripping Taps driving me mad. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Morning I hope someone can assist as the constant dripping is driving me crazy.
On the image supplied please can someone tell my how to change a washer on these taps?
Surely it must be an easy 5min job.
Thanks in advance .
Welcome to our world Jason!
Firstly, it IS indeed a small quickish job when you have the correct kit.
However, and here comes the bad news, your tap doesn't use washers. It uses what is termed a 'cartridge' and there are approx 5000 in use in British taps. The only way to determine exactly which you have is to remove one and do some accurate measurements. It is impossible, genuinely, to tell from the outside. This is why I invented my product.
If you are a competent DIYer then take a nose at our site where you can buy a small kit to do the job. If not, then on our site (under approved installers) you will find a local plumber with a kit to do it for you.
The tap you have, as I'm sad and recognise it, is actually made of reasonably good brass so is worth keeping. Putting new cartridges in will set it back to perfect working order and mean you can keep it for as long as you wish. The alternative is to throw it away and start afresh.
To get a similar quality of brass you'll be looking at approx £200 just for a tap (the kitchen needs something reasonable as it's used more than ALL the rest put together) plus fitting. :)
Reply to Dripping Taps driving me mad. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
Hiya - posting in this forum as I'm guessing this relates to my neighbour above's boiler, but I may be wrong so please say if so. Basically the...
Morning all, I recently changed the washers on my kitchen mixer tap due to it dripping, I reseated it using a tool but it's still dripping. I...
Hi, my tap is dripping. It’s not constant. Sometimes if I try that extra tighten it stops but most of time slowly dripping It’s dripping from the...
Deleted member 120897
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
