Discuss Drill bits for tiles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dave1
Which ones do you use and how much? Just been looking at the 365 stuff which looks good but doesn't seem to give you many holes on porcelain tiles.
for what size eg normally red and brown plugs or bigger
I use the arrow heads for normal holes (plugs) and screwfix own brand tile hole saw for the rest
Bosch multi construction bits (the ones with the blue flute) are great for tiles and not expensive, work well on porcelain too other than the extra hard grades
I found the B&Q tile hole saw drills to be good and not expensive. Screwfix probably do same type. I have Hilti tile hole saw drill and it seems top quality, but they are expensive
For brow plugs I use a 4mm Irwin cordless bit, then open it up with a 7mm. On porcelain, Use on slow speed and keep it cool. Be patient.
For diamond bits try Ats diamonds. Speak to Allan. They do the dry and wet diamonds. If you tell him Paul walker gave you the contact, he will give you a 10% increase! :8:
Seriously, they give a very good service.
Good for diamond discs too! All their own brand.
Home | ATS Diamond Tools
Reply to Drill bits for tiles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
