Discuss Draining heating system in top floor flat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hello,
I recently moved into a new property, after noticing a few of the radiators having cold spots I put a chemical cleaner into the system to run for a few weeks.
I’m unable to find a drain off at lowest point of system (laminate flooring) there is only a gate valve connected to the boiler flow pipe for draining it down partially.
What’s the best solution for when it comes to draining the cleaner out ? Do I need to drain as much as possible out from the gate valve then buy a wet vacuum to clear the rest?
Thanks in advance for any advice.
Which brand and type of cleaner? Check the instructions on the pack first. These take priority over anything some guy on the internet tells you, otherwise...
If it's unfeasible to drain the system reasonably fully, just refill with water, circulate for a few minutes so any of the cleaner left in the pipework is diluted by mixing, then drain again. One of these extra rinse-cycles is probably enough, and two almost certainly is.
Don't forget to add the correct quantity of corrosion inhibitor to the last fill.
Thanks for the reply.
I added sentinel x400 which states system must be fully drained after 4 weeks maximum.
Seems like that will be the only option as not prepared to start ripping the floors up looking for drain in my new home.
I will be leaving cleaner in for another week then draining and adding sentinel x100 inhibitor and a magnaclean pro filter.
Why don’t you blow it out. Hook up a mains water connection using a radiator stabbing and make another elsewhere ...off to the bath eg.
If your putting in a mag filter put an mt cock in as well and off you go . Let us know how you get on Rob Foster aka centralheatking
Reply to Draining heating system in top floor flat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I’ve been having some issues with my heating system. I noticed that the overflow was intermittently dripping and saw on the tank that i should...
Deleted member 120897
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single...
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
I'm attending a wet underfloor heating system, it's an old one ..No flow meters, just adjustable valves on the returns with conventional...
