Discuss Drainage / septic tank advice in the USA area at PlumbersForums.net
townfanjon
Subscribed
Customer mega house , two soil pipes , both outside and around 5/6 meters apart .
One vented to atmosphere, the other has an AAV fitted , the one with the AAV is starting to give drainage problems , blocked basin , pan nearly fills up and then falls immediately, shower waste gurgles . Didnt have ladders on van so not sure if the AAV is suitable for outside . It all empty's into a septic tank, is there a reason for the AAV ? Can I take it off ?? Etc etc .
I am no drainage expert and would appreciate some advice ....... Thank you in advance .
Agree with Simon, TFJ. how close is the soil pipe venting to any window or air brick? May have been used to overcome foul smells etc entering the building .They do make external versions but best to vent to atmosphere where possible.....regards Turnpin
Cheers guys , I just couldn’t see the point of it , especially as the house was built with all the scaffolding it seams easier to put 2 soil pipes up.
Reply to Drainage / septic tank advice in the USA area at PlumbersForums.net
