Discuss Doc m handle i.d. in the USA area at PlumbersForums.net
WC1
It's the lever I need - it's got an extra long threaded section and came with 2 X wedge shaped washers to take up the curve of the cistern wall. Thanks
This is the one you have but look discontinued
Amazon /Square-Cistern-Paddle-Handle-Disabled/dp/B019IQ0UME
Reply to Doc m handle i.d. in the USA area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
