Discuss Do I have the right products to cap off a lead water pipe? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I need to cap off an old lead water pipe in the garden as I have an new MDPE pipe water supply.
I have a Screwfix
FLOMASTA COMPRESSION REDUCING LEAD TO COPPER COUPLER 7LB 1 X 15MM (53125)​
A piece of 15 mm copper pipe.
A
FLOMASTA SOLDER RING STOP ENDS 15MM 10 PACK (68435)​
Obviously just one of these.
And a freeze kit.
My lead pipe is approx 24 to 25 mm diameter.
I believe I need to file down the lead pipe once cut to get the adaptor to fit.
Also believe that I do not need an insert for the lead pipe.
Is what I have and what I'm thinking correct?
Any information would be most appreciated.
Thanks.
Best to get a 9lb x 15mm one also
And correct
If it's not what you are planning, you need isolate the dead section at its source. You don't want a blind section of lead (or anything else) connected to your water system.
Reply to Do I have the right products to cap off a lead water pipe? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
