Discuss Direct unvented element in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have just seen one can do a G3 course with Gledhill for £90! Seems a bit of a bargain for someone without the G3 ticket.
It’s ridiculous my college wouldn’t let you do the unvented ticket until you have the NVQ2
Relax, the Gledhill course has pre-requisites:
"Candidates will need to have an NVQ or equivalent craft qualification, or be working towards one; or have significant experience in either conventional heating engineering or plumbing"
I'm also pleased to see that a pass requires 100% in the assessments.
Your original post asked whether as an unqualified DIY'er you could replace a blown immersion element on an unvented cylinder...The overwhelming response was NO and you were advised to have the work done by a G3 qualified engineer..You've confirmed the element has failed, told us how much you can buy a replacement for and the cost of doing an unvented course with Gledhill...so maybe you should do the course, get your G3 ticket, buy the part and do the job because I don't think we are likely to change our minds!!..I'm out too.
Was only asking opinions.:rolleyes:
Opinions do not matter. The law does. Fact is, you could do it and it'll be fine. You could do it and it goes wrong - not always as you may think! In that instance, not only do you have the moral implications but legal too. In law you will be fully cupable - as indeed you should be.
Take the ADVICE (not opinion), be the sensible and responsible Dad (put away your ego) you are and help your daughter get it done properly. You know it makes sense ;)
I think more so than shooting you down we err on the side of caution. Look at it from our perspective; the first piece of advice we’d give is get a G3 in. You then follow up with I’ve tested the immersion and it’s fubar. We then follow up with get a G3 in to ensure the correct part is sourced. You then follow up with I’ve sourced the element. What else are we to think other than you’re contemplating doing it yourself. Likewise look at the other side of the coin the next unqualified person reading this may think how easy it is to do
Reply to Direct unvented element in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
Hi Guys, has anyone come across the ACV cylinders, my client has SLE-160 in the loft and there is no drain off boss.. The cold inlet is on the...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi everyone, I'm a (somewhat, I hope...) competent DIYer and just want to get some advice if my suspicion on a problem we're having is correct...
Hi, New to this forum and also complete novice who knows pretty much nothing about plumbing. However I have done quite some google searching...
5K
