Discuss Direct unvented element in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In addition to the problem my daughter has with hot and cold flow rates varying wildly reported in a previous post now the bottom element has expired. Hence she is only heating about 1/3rd of tank at most and then on day rate electricity. Am I being Mr DIYer allowed to drain the tank and fit a replacement element. There will be no interference with any of the pressure valves.
As it must be the correct element. An off the shelf one will not be in line with the manufacturers requirements
Like Gas Safe, the G3 qualification is there for a reason. If your in any way sceptical just take a look online at the videos showing what can go wrong!!
Reply to Direct unvented element in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
Hi Guys, has anyone come across the ACV cylinders, my client has SLE-160 in the loft and there is no drain off boss.. The cold inlet is on the...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi everyone, I'm a (somewhat, I hope...) competent DIYer and just want to get some advice if my suspicion on a problem we're having is correct...
Hi, New to this forum and also complete novice who knows pretty much nothing about plumbing. However I have done quite some google searching...
5K
