- Messages
- 998
So I when to service a Baxi Baroque today & also changed the jets on it as the originals were blocked & fire was not lighting. What an arsehole job it turned into! servicing the fire and changing the jets was fine. Whipped of the closure plate to have a quick inspection and clean, I say whipped but actually I had to cut it of with a Stanley as it had been gunked on with large amounts of silicone, due to the surround being made up of an uneven stone finish and it not sitting flush back to it, I then scraped all the silicone off the surround(gingerly) and off the closure plate frigging took me ages!
Anyway the catchment space opening was all wrong for what the Installation instructions required; it was too narrow and too tall however it did meet the depth requirement & the closure plate covered the fire opening, the chimney was an unlined brick built one looked to be a 225x225mm square & In good condition, I thought here we go I bet it fails the performance test with the smoke bomb, But I put two up it in quick succession and it had a good draught, no smoke leaks in the loft or any other locations. Quick look outside no terminal... -_- according to my gas book a gas fire in this size and type of flue does not need a terminal. I strongly recommended to the customer that a terminal and bird guard be fitted for good measure as I found sticks and bird stuff in the cachement space.
Anyway I fitted the closure plate back on with hefty amounts of heat proof silicone(to get a seal on the uneven stone surround) and some closure plate tape for good measure. Seriously I don't get why the original installer didn't make up a nice rendered flush surface just for the closure plated to sit on, thats what I have done in the past it makes for a much neater job!!
Fire working like a treat, spillage test passed no problems, burner pressure spot on, nice flame picture jobs a good un!
Anyway the point of this little story, is to find out what you guys do in similar situations.. I have come across loads of gas fires where the fire opening is of an incorrect size, But the fire works safely, Is this NCS? My main concern on this one was the Lack of terminal my inclination would be to put a standard pot+bird guard on this, Even though my gas safe book says its not mandatory only recommended
