Discuss cutting into pipe that looks like overflow pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jase158
hi all, Just been to see a job that I am starting next week, the mains pipe is on pipe that looks like overflow pipe, rather then copper or plastic, I need to cut into it and convert to copper somewhere. Any idea what it is? the whole building is run from 1 mains pipe and boilers in boiler room. so need to get fittings before they turn water off, cant really go and get fittings. other option is to try and clamp the pipe to stop it snapping whilst I loosen the stop tap up.
Could be acorn pipe! If it is solvent abs you will need to find a local merchant that stock the lead lock type compression fitting. Few housing estates up our end where it was used. Think it's about 18mm
It sounds like durapipe. You can buy adaptors or disconnect it from a valve or somewhere with a thread and renew it from there.
cheers everyone, will try the Phil mac fittings, I have got some in garage but they are 3/4 to 25mm!! typical!!
Depending on age it may be Poly-York if it is be carful it gets brittle.
Reply to cutting into pipe that looks like overflow pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello everyone. New to the forum and looking for assistance / advice. I live in a rented house with a not very co-operative landlord. I have just...
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by...
Hi I need to this cast iron pipe back as my new back to wall toilet won’t fit otherwise. Cutting it back i am going to lose the collar. So what...
I've had a burst pipe under bathroom floor. Ive had it dug up and made safe with the affected pipe cut and end caps fitted. The pipes are cover...
