Discuss crackin' a nut 'ere in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Amir Akhtar
Biasi riva M90e 24s
works perfect for hot water!
comes on for heating for about 15secs and doesn't ignite again for 5 mins.
changed thermistors and pump!
hmmmmm???
Do the rads get hot? Flow return temps when it is running? you have changed the pump but there may be a Div valve issue, have you checked it?
Kettling/overheating???
Give us some more info and we may be able to help.
If i put my magic thermistor on thats in my pocket stays on for longer about a min and kettles and goes off.
two radiators working. flow and return were both hot. checked diaverter motor seemed to be movin on hot water
yes but have you ruled out time clock or room stat issues?
Reply to crackin' a nut 'ere in the Plumbing Jobs | The Job-board area at PlumbersForums.net
