Discuss could someone tell me what size connectors these are in the Plumbing Jobs | The Job-board area at PlumbersForums.net
They are for the bath I have taken out, I need to get some longer connectors.
Why have they used 2 different size pips and what are the sizes of the flexi connectors, the bore looks different.
one 15mm to 3/4
one 22mm to 3/4
snowhead is spot on I would say.
Also pipes look quite restrictive/narrow, ask at plumbers merchants if they have any full bore type as it will allow better flow through,
Cheers
Better still run in in copper and use a 22mm and 15mm tap connector to guarantee full bore flow to the tap of at all possible
Reply to could someone tell me what size connectors these are in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Sonya K
