Discuss Copper pipe cutter for plastic fittings in the USA area at PlumbersForums.net
Hello, I have a traditional “disc” type cutter that you wind down onto the copper pipe but I’m told it’s best to have a cutter or “slice” that leaves a chambered edge on the copper pipe so it clears the plastic fitting O ring. Can anyone recommend the best cutter for 22mm and 28mm copper pipe when using H20 plastic fittings? Thanks in advance
Solder or compression on the copper. Only time I've really had a plasic fitting let go recently was on the copper side when I had to join copper to hep2o plastic. I don't trust hep fittings on copper. If it's a diy job go for comp fittings. Easier to dismount and re do than hep with their pita demounting key thingy. Little jet blue compound behind the olive will do. If you must use plastic on copper I'd use speedfit as there is a mechanically tightening locking ring.
I use monument pipe slice, just keep it clean and a little spray of silicone grease from time to time to keep it in good working order, oh and a new blade when needed.
Push fit is ok used on copper but I use polyplumb fittings, the dark grey ones, easier to take apart if you think it’s not quite gone together properly than the hep.
Sf are uglier than the hep. But then all plastic is pretty pug fugly against a well made end feed joint.
Reply to Copper pipe cutter for plastic fittings in the USA area at PlumbersForums.net
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
Hi folks I need to fit a kitchen monobloc tap temporarily. A new sink unit will be going in soon so this will just be a stop gap. The current...
T
I have recently moved house and would like to move a radiator from a side wall, to one below the window as is more pleasing to the eye. I...
2K
I had a history at my home with the oring failing on my tub spout leading to water leaking through the pipe opening in the wall. I had put new...
Hello, as per title I need to cap off the hot/cold feeds to the bath before I rip it out. Its 22mm copper feeding into flexible pipe to the tap...
2K
