K
kc1
I'm planning to use 15mm plastic pipe into conex compression fittings (with inserts of course).
The pipe manufacturer recommends using copper olives (rather than brass ones).
So i've bought some copper olives, but they are only 6mm wide compared to the 8mm ones in the conex fittings,
and consequently I run out of turns on the compression fitting thread, before being able to apply the recommended (by conex) 1 1/2 turns.
Can any suggest where i might get copper olives suitable for conex fittings, or some other solution!
Kevin.
Kevin.
