Discuss Constant air in 1 rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
malagabob
Had a Worcester Jnr condensing boiler fitted about 6 months ago as a replacement for open vented system. I fitted a replacement but larger rad in living room and 1 same size but double panel in a bedroom.This is the one that gets air in constantly.
All other rads are original.
Have never had air problems with original system. Have checked for leaks when system cold.
Does the air smell pretty bad?
No cant say it does, but have not got my face close enough to smell anything. If it smells what would that tell me?
Move curtains out the way and try to ignite the 'air' if it lights it is hydrogen a by product of corrosion. A flush and chemical treatment will sort this.
have any automatic air vents been moved or if there were original AAVs have the isolation valves to them been adjusted
i dont think its hydrogen from corrosion as this takes a while to build up, i suspect air is being sucked in from some where, probably caused by bad pipe lay out which has been patched up, then what ever the patch was its been removed when the new boiler was put in
Reply to Constant air in 1 rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have had a problem where 2 downstair radiators are not heating up the same as the rest of the radiators around the house, now previously i had...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
Hi, I noticed some months ago that my Megaflo auto air valve was leaking so I replaced it, the replacement valve has also started to leak with a...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
