Discuss Connect Siemens RWB27Si Timeswitch wireless thermostat to baxi combi boiler. in the DIY Plumbing Forum area at PlumbersForums.net
Yes it's a combi and it has the programmer wired externally but no thermostatYes this should be ok, but check it out first. Iād say being a Baxi, it might not have 24v. Is it a Combi boiler?
We currently have a Siemens RWB27Si Timeswitch connected and I want to connect a Salus IT500 receiver. Just want to know if the wires from the boiler will operate it, with a straight swap?Yes it's a combi and it has the programmer wired externally but no thermostat
currently have a Siemens RWB27Si Timeswitch connected and I want to connect a Salus IT500 receiver. Just want to know if the wires from the boiler will operate it, with a straight swap?Yes this should be ok, but check it out first. Iād say being a Baxi, it might not have 24v. Is it a Combi boiler?
Think I might go for hive v3 now.Might not be a straight swap, but should be doable. I believe Salus are not very good. When you have purchased it, post wiring of the Siemens and we can advise on the wiring.
This what i have done, is it safe to switch on!!!So the current programmer is using terminals 2 & 4 but a video I watched says use 1 & 2 on hive. Will I just swap 2 to 1 and 4 to 3 on new receiver?
Reply to Connect Siemens RWB27Si Timeswitch wireless thermostat to baxi combi boiler. in the DIY Plumbing Forum area at PlumbersForums.net
