Discuss Condensing Boiler Recommendation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Radioman
I need to replace a 22 year old vented wall mounted gas boiler with a heat only 30 kW condensing boiler. This is in a 4 bed 1.5 bathroom property I am flipping, so I am looking for a cheaper solution rather than an installation that I would have to live with.
What are the cheapest and easiest to install?
Hi Radioman, I would be inclined to look at Ideal or Glowworm. They are all easy to install for the right installer. Ensure you get someone in who is GSR. They may have their own opinions on the boiler to install but get a few quotes in. Where are you maybe some of the lads on here could help you out
If you post in the I'm looking for a plumber/gas engineer section I'm sure someone will be happy to help
If it's LPG the only ideal option for a heat only from ideal would be the 30kw
Reply to Condensing Boiler Recommendation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
