Discuss Condensing boiler 20 degree differential in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bruno lang
Flow pipe temperature 70 degrees. Return pipe is 55 degrees. What would I need to do to get the 20 degree differential that they look for?! Turn down pump speed? Close off balancing valve on rads and cylinder until temperature on return pipe drops? Or is dere another trick?!
You could turn the pump speed down, If its a combi you might want to double check with the manufacturer first.
You could Adjust the boiler output - if its oil, if its gas it will modulate
If you close off rad balancing valves your only going to increase return temp as less heat will be going to the rads
Reduce flow to rads. Don't disturb combi pump setting.
You need 20 degree drop through a rad.
Reply to Condensing boiler 20 degree differential in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Wb 4000 recently installed, and just balanced the rads with around 16 degree delta across most rads. I'm trying to make sure that the return temperature to the boiler are less than 55 degrees to ensure condensing is occurring. But in the service menu it only shows the primary heat exchanger...
Return temperature
R
WB 4000 installed a few months back, just balanced the 7 rads - managed to get around 15 degrees delta across most rads. Not quite the 20 degrees but still. Flow set to 60 degrees for now. 1.Obviously I want to ensure the return temperature into the boiler is below the 55 ish degrees needed for...
R
Hi, The outlet of all my radiators are at 55°C, but the boiler keep showing the Return Temperature is 60°C (and keep raising at 1°C/min rate) Also the flow temperature keeps going up above the set point and when it reaches +5°C above the set point, the boiler shuts down (even before the room...
Renato
R
Morning all, I have a Worcester Bosch 8000 life 40kw boiler on system with 7 radiators and the boiler is located in the loft of a 1907 end of terrace house. It has been range rated down to 50% and I currently have the flow temperature set to 64, due to slow warm up. I recently purchased a...
Simon from Watford
