Discuss Concerned whether KX(?) Solder ring fittings safe for drinking water? in the Fittings & Pipes area at UKPlumbersForums.co.uk.
  1. Bazza
    Bazza New Member
    Hi, first post :)
    Purchased a number of fittings today and long story short, after being referred to as Yorkshire fittings over the counter, I suspect this was a bit misleading?.
    How do I know if the solder ring fittings purchased are a) safe for drinking water (and b) presumably, if that means also WRAS approved).
    The fittings don't have the Yorkshire brand squiggle, only say:
    EN1254 [KX] LF 22.
    Did check online and seemed the EN wasn't enough to say, guessing KX is the brand but hard to diagnose online and may not be reassured by staff's say so in the shop now.
    Thanks,
    Barry
    • Like Like x 1
  2. ShaunCorbs
    screwfix?
    and they will be fine tbh even the leaded solder versions would be fine (yes we all know were not allowed to use them but didnt do us any harm in the past )
    • Agree Agree x 1
  3. Bazza
    Bazza New Member
    Local plumbing chain...
  4. ShaunCorbs
    Your fine then
  5. Bazza
    Bazza New Member
    Rang them up "First time I've been asked that by anyone in 10 years. I don't actually know, it's the only (non end feed) we stock". Didn't know the brand either of what they buy in...
    As an engineer of another trade it's surprising that something so fundamental is not clearly denoted in the stamped standard.
    Did you recognise the brand from screwfix or was that a punt?
  6. ShaunCorbs
    Screwfix have the same your fine either way just use them
  7. Bazza
    Bazza New Member
    Ta
  8. steadyon
    steadyon Active Member
    KX is, I think, a Chinese brand / company. EN 1254 is the appropriate British Standard for such fittings, and if a fitting meets these standards, then WRAS approves them, subject to various provisos.
    The market is full of fittings which may or may not meet the standards and may or may not be WRAS approved. If you want to be absolutely certain, buy known brand fittings such as Yorkshire Pegler or Conex. For most domestic applications the "unbranded" fittings are adequate. Whether you would have an argument with an insurance company if one failed and caused damage I don't know.
    • Like Like x 1
  9. Bazza
    Bazza New Member
    Lovely. Had also seen KX was probably Chinese (not necessarily bad...), oddly their website didn't list solder ring fittings amongst the range but not to worry there. Did wonder if the LF was lead free but that'd be wishful thinking and didn't want to suggest upfront.
  10. Clanger
    Clanger Active Member
    Although I agree that risk of applying too much solder is reduced with solder ring compared to end-feed, we may not be as safe as we think. Scientists now argue strongly that there is no safe background level for lead in the environment and this means in pipes. This World Plumbing Council report (see page 33 onward) published this month, highlights the serious health risks associated with imperial copper systems in England (pre 1986) that have leaded solder joints http://worldplumbing.org/assets/upl...d-training-scholarship-report-Simon-Reddy.pdf
  11. ShaunCorbs
    Yes I know Simon well
    Didn't do ours parents or grandparents any harm, and there's miles and miles of lead and leaded solder pipes around that arnt going to be changed any time soon
    If there was a problem don't you think the water board will have a mandatory change in place
    • Agree Agree x 1
  12. Clanger
    Your comments are no different to others on this report and indeed, I think your reasoning is good - the water board should have spotted a risk, and should have acted - but the risk is on domestic side, so in some ways beyond their remit - at some point we got to remove all of these lead joints, so we should be working on measuring the risk and taking action to remove that risk to health - in Hong Kong people being arrested over this and the matter is still not resolved.
  13. Clanger
    Great first post Barry and I like your style in terms of being conscientious about public health - Top Professional!
  14. ShaunCorbs
    TBH I don't think they will do anything, I'm sure we're still going to see leaded jointsbfor at least 60 years
    • Like Like x 1
  15. Ric2013
    Ric2013 Plumber
    With experience, it is possible to distinguish lead free solder from tin/lead solder with reasonable success. Obviously it is much easier to compare a roll of solder with another roll than the solder inside two fittings. Realistically, is it likely that a Yorkshire-style fitting of any style, especially if sold in a merchant's shop, will contain lead?
