- Messages
- 5,439
Ones where the drop valve end of flushpipe is bigger and pan end of flushpipe bit smaller and a smooth circular nut is found on flush pipe under cistern. Does anyone know if there is a universal 2" valve that will work in these? And seal properly to existing cistern/flushpipe?
Also is the end of the flush pipe standard 1.5" where it enters pan so failing that you could change cistern and flush pipe to a fluidmaster or similar? Thanks
