Discuss Compression fittings in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I need to replace the flow and return in the loft but using a torch is out of the question, is it wrong to do it entirely in compression? As don’t really like pushfit and press fit the cost doesn’t work out ?
Go for it. Good choice for your project. Have you done any before?
Don't forget your pipe support so pipes not flapping about.
Cheers,
Roy (Amateur)
Reply to Compression fittings in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
