Discuss Competent persons scheme in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ted808
I know it's a mouth full! My cust want a certificate for putting in a bath, basin and new position of loo....I'm not sure how to go about it! Any advice? Join APHC and then one of the many other schemes?... and how long does that take? I suspect he won't pay up until I've given him this bit of paper? :smartass: :bat:
Sounds like a bit of a bellend to me! Was this mentioned before work commenced? If he tries it on, show him how competent you are at undoing your work.
You need it in your terms and conditions that building consent and approvals are not included in your estimate. I then put in my estimate as a line that the boiler installation and commissioning will be registered through the oftec competent person scheme, who will then notify building control who will issue building regs certificate.
Also have a line that basically says if I havent said im doing it then its not included..
join water safe, theyll send you a little pad of certificates, use one of them, custard wont know any different, done it many a time, no fee to join either. :):)
i was going to join them. but it seemed more hassle than joining gas safe so i never bothered
That would be criminal damage then as you cannot intentionally damage or remove fitted items in a customers house ?
not if its not fitted correctly or satisfactory to your standards ;)
To be honest when it has gone that far there is not many customers who are realistically going to let you put a foot in their property so normally a non starter !
Mate of mine had a glazing firm and was a developer too his groundworker had a customer who did not pay unfortunately the brakes failed on the jcb at full pelt luckily he managed to jump off before it went through the house ?
Funny how he was seen jumping out the cab on the other side of the house ?
Must have been an optical illusion !
Reply to Competent persons scheme in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
Hello All and thanks Lou i did write a reply but it would not let me send it? i am not sure what I am meant to write and I do not want to come...
  • Locked
WITH ALL THE REGULATIONS IN PLACE THESE DAYS, WE MUST BE SAFER NOW. AS YOU WILL SEE FROM THE (CO) CHART AT THE BOTTOM WITH ALL THE SAFER DESIGNS...
7K
  • Locked
I'm looking to be registered for most of the technologies available, and the costs for CPS are going to spiral out of control if i'm not careful...
  • Locked
Hey all. Just had an interesting experience tonight. Just finished a bath install with tiled bath panel and wrap around tiling today which was...
