Discuss Combination tank wall mounted. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
There’s a combi tank wall mounted in the actual flat and the new kitchen tap is higher than the HW feed from the cylinder.
I’m looking for suggestions on a pump suitable for the bathroom and kitchen for the HW only. There’s only one person living in the flat so there’s no chance of more than one taps being open at the same time.
Thank you all
If it's one of these your talking about, you can't pump them. Because you lack the required stored water the pump will run dry.
We ask because we get people log on here from all over the world so we need to know what sort of install we are dealing with. You will struggle to pump your hot
Not even with a shower like pump, a salamander type i.e.
no sorry
best option is to fit an unvented if the water mains will let you and your g3 qualified
Reply to Combination tank wall mounted. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
Hi everyone, I need to replace the kitchen tap, all my neighbours have two single taps in their kitchen and bathroom whereas I have a single...
Where and how does the water supply work and is there only one rising main pipe and where is it usually located? I am top floor flat, mains fed...
