Discuss combination cylinder help - please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
charfnd
hiya, i have a an indirect combination water cylinder in my house, obviously i have very poor hot water pressure from this. my question is can i just add in a header tank in the loft to increase hot water pressure?
many thanks
thanks for that, is there any way i can increase the hot water flow cheaply? want to upgrade to a pressureised system but cant afford it at the moment.
thanks
Well after considering the situation and taking everything into account, mulling it over with others and checking the traditional ways and modem advances, and studying the variables involved, not jumping to any preconceived conclusions I have come to the conclusion that the members answers in the posts above and probably any future one's below are and will be correct in their assumptions
But then again......
Think you my have to bite the bullet and invest in a good plumbing system
if he takes that long to do a simple job when working he must be raking it in at ÂŁ75-00 an hour!!
Reply to combination cylinder help - please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot water to our plastic header tank in the loft every time we turned the heating on. We first noticed an issue with a leak in our bedroom ceiling which we...
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked overflow/expansion pipe. Hence the header tank then reaches the overflow level and the overflow trickles out. I have changed the ball valve washers thinking it was...
I have a vented hot-water cylinder that was installed when the house was built - 38 years ago! It has a header tank in the loft and the cylinder is located directly above the ceiling of a new and expensive kitchen. It does not leak and causes no obvious problems. Should it be replaced? Advice...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are about to upgrade the upstairs bathroom and are considering installing a shower bath. My concern is that although there is more than sufficient...
