Discuss Combi boiler whistling in the Central Heating Forum area at PlumbersForums.net
Hello,
I have a potterton promax combi boiler which has developed a whistling/kettling sound when turning on the hot tap.
The sound seems to reduce has the tap is slowed. I have also noticed this sound occurs when the boiler is turned off and the tap is running??
I can reduce the noise by opening and closing the cold water inlet on the underside of the boiler.
Any clues? Is this something a gas engineer could solve?
Reply to Combi boiler whistling in the Central Heating Forum area at PlumbersForums.net
If you are qualified to do a Gas Safety check on a property I assume that entails checking the boiler. If, when checking a Combi, you notice the...
Hello The heating side of my Ariston Combi A23 has stopped working since a new 3 way valve has been installed. It's been a hugely reliable boiler...
R
Hi, The outlet of all my radiators are at 55°C, but the boiler keep showing the Return Temperature is 60°C (and keep raising at 1°C/min rate)...
Renato
R
Hi guys, my boiler seems to be making a whistling sound after a while its on, if I tap it firmly it goes away, is this something to do with...
Deleted member 120897
